- Joined
- 15 Nov 2005
- Messages
- 132
- Reaction score
- 1
- Country
Contentious as in you should not put more than one socket on a spur off a ring final?
If your design current is 1kW, this is approx one third of 13A. Why not take a spur off the ring final with a single 2.5 cable, put a 13A FCU in and run 2 sockets off that?
That is, rather than run a 4mm cable for the spur on its own, use 2.5mm to spur into a 13A FCU which then feeds 2 sockets from 2.5mm cable?
That would work too. I don't understand the pros/cons of each approach.
