corsa (n) 1.4 16v ecotec
12 Sep 2006
Tyne and Wear
Hi i done i diagnostic test on my corsa and come up with these codes--
Can anyone tell me or give me any advice how to fix theses problems
85 = injector 5 low voltage
56 = idle speed controller or circuit short to earth
29 = fuel pump relay or curcuit voltage low
92 = cam shaft sensor or circuit poor
35 = idle speed control valve or circuit low voltage
33 = map sensor voltage too high
also engine running rough and theres a whining noise from timing belt
Jeeeeez! Time to send it to the scrappy aint it?!
Have you cleared the codes and driven it for half hour or so and see what ones come back up?
Some of them could be intermittent codes which have been logged for months/years.
Did you read it with the engine running?
i originaly bought the car as a project just for a bit of experience as im training to be a mechanic myself
no didnt read it with engine running but i will do anyway
so if i run it for about 30 mins will that reset the codes?
No, you need to reset the fault codes with the fault code reader, then take it for a drive to see if the same codes come back.
i used a fault code reader and got them codes but dont know how to reset them thats all. i used it again after fixing a few probs but still getting same codes
The codes will be stored there til theyre erased. If your code reader cant erase the codes too, you'll need to take it to a garage that can reset them.
Doesnt need to be main dealer, any back street garage with a snap-on or the likes diagnostic tool will do it for a drink
