I've narrowed the boiler choice down to the above two but struggling to make a final decision.
Intergas because of it's simplicity and excellent heat exchanger.
Atag because of it's flexible flue arrangement.
The Atmos would have been a good compromise but not sure whether you can still get hold of these.
I am ordering in all the equipment because we get a good trade discount from our supplier rather than through our plumber.
We are replacing a Range Powermax 155x with a system boiler and unvented cylinder. The Powermax flues to a Ridge Vent, at the moment the loft isn't boarded so I can't get up to check the outlet spigot size, does anyone know what size this would be or what adaptor would be required to suit the Atag boiler?
With the Intergas when using the Fixing Jig part A is it possible at a later date to replace the expansion vessel without pulling the boiler off the wall?
Cheers
Mark
Cheers
Mark
