- Joined
- 24 Sep 2005
- Messages
- 6,345
- Reaction score
- 269
- Country
Exploring the ratchet crimper.
Tried some pictures.
I am sure the crimp deformation will be different with an inserted wire providing resistence...
A...
The crimped tube in A, above, was deformed with the larger arc jaw profile in B as shown.
B...
The tube in B has been deformed using the jaw profile in A. In this case the tube has been shaped into a smooth oval section without the split edges overlapping...
A couple of Q's.
If the distinctly differing jaw profiles, twixt one side of the tool and the other are the norm, which jaw should be crimping the inner metal tube?
Can someone explain the correct method and if there is a trick to positioning the tube split seam to best benefit the crimp?
A...
B...
A couple of Q's.
