Basically my boiler is dead, and needs replacing. I've explored that elsewhere, but it's not relevant here (I think). Should it have any significance, it's a Potterton Netaheat 16/22, non-combi gas boiler, and it's ~25 years old.
How do you know the boiler is dead? Has it been checked by a registered engineer?
[/quote]
No it hasn't, it;s been diagnosed by similar boards to these, but I can't afford an engineer call out.
I did do lots of phoning around whilst I was at my mothers in Kent (I don't have a phone) to find an engineer that would do a free consultation to assess it (several were advertising it), but most would only do it if I was looking at repalcing the CH system, not just for a repair, and the one company that said they would come and look, later cancelled on me and said they weren't interested.
Tinkering with the boiler has shown I can get about an hours use out of it every 3 days at some random point, but it consumes gas the whole time, even when not lit.
Are you saying that it
leaks gas? That's dangerous and the boiler should be disconnected and the supply capped off.
When I turn the boiler off no gas is consumed. When I turn it on, the fan runs, the solenoid clicks etc, but 99% of the time no pilot, and no flame. Watching the gas meter however shows that gas is being steadily used all the time however, and there's a slight whiff of it in the sideway where it vents.
Whether it's consuming the full amount of gas and just dumping it unburnt, or just a small amount leaking I don't know. I suspect the latter, since you can't light the air from the vent (after off for 24hrs, no build up etc) but I though it best to just turn the whole system off.
What tinkering do you do to get it working?
I tried all the tapping the wires and circuits with a wooden spoon whilst it was on to check for loose connections as suggested, took off the clear plastic tubes (pressure valve?) and sucked and blowed etc, none of it made a difference.
Turning different parts of the system (thermostat, CH clock and boiler) off and on in certain orders seemed to make a difference, but now I think that was just random chance - I can't get anything to work repeatedly - sometimes it comes on, mostly it doesn't. Sometimes it would come on of it's own accord, after having sat there on but not working for hours...
As you are on benefits, you may be eligible for a
Warmfront Grant to replace the boiler.
Thank you, I wasn't aware of this... I will look into it.
