when the casing is on it is fine on both accountssecurespark said:The MK board's modules are leaning like the tower. Why is the bottom of the casing distorted?
SS Whose board are you using there?
That's what they do.securespark said:The MK board's modules are leaning like the tower.
Presumably that's also something that MKs do...?Why is the bottom of the casing distorted?
securespark said:Why is the bottom of the casing distorted?
Well he did only pay £42......fubar said:securespark said:Why is the bottom of the casing distorted?
Because the busbar finger protector is incorrectly fitted.
Michael
i'm gulity for that one, can't say 100% the spark didn't fit it in a similar fashion but i certainly removed it and put it back after he'd completed the job and left.ban-all-sheds said:Well he did only pay £42......fubar said:securespark said:Why is the bottom of the casing distorted?
Michael
supersparks said:ahh, thats why, that is whats commonly known as rats nest wiring, not unsafe but far from good quality(though you get what you pay for!)
this took just under 3 hours including tests and is what id call a rush job...
(also included finding a lighting fault-about 15 mins)
supersparks said:earths 1
L.Spark said:No offence Dingbat, but how can you question SS,, after all you clearly don't know what your talking about
You Don't use a loop tester to verify earthing connections, this is dangerous and could cause harm to someone, and you would have a Installation Certificate, and NOT a PIR for a CU change, surely you know this !
L.Spark said:lol dingbat, I read only from what you wrote, and you decribed how you found the missed earth connection with a loop tester, when you would find this through continuity.
L.Spark said:no you wouldnt take everything apart, but AFAIC all old wylex boards should be replaced with a more modern board which offers better protection.
