Apologies for all the repetition in this reply - but I'm replying to repeated points
No, they are not an 'invention' by manufacturers. The values are assigned by manufacturers, in accordance with the relevant standard.
I agree it was a bad choice of word. What I meant was that the sort of accessories we are talking about generally come (at least as far as the average user is concerned) with a single 'rating', often even moulded onto the product (e.g. a "10A switch" or "20A JB"), which the manufacturer has assigned (in accordance with any relevant standard) on the basis of of assumptions about likely usage.
My point was that there are numerous ratings that can be assigned, with different meanings as well as different values, depending on the product and on the standard. If you ask about a specific rating for a specific accessory then it might be possible to provide an answer.
I understand your point. However, again,
my point is that (for the sort of products we are talking about) the end-user is (usually) presented with a single 'rating', and needs to understand what it means.
Of course the users of those accessories are not going to read through all the relevant product standards, which are written for manufacturers. They will just use the installation standards and MIs.
Again, exactly - and if (as is usual) all they are presented with is a (single) 'rating', they need to understand which rating it is, hence what it means.
However you seem to be trying to go further than that and understand some of the decisions made by the standards committees, but you need to be clearer about the exact question you're asking. For example, consider a "10a switch". What is the utilization category (nature of the load, frequency of operation, etc) for that rating? Is that installed, or in free air? Is it a switching rating, or the conditional current that can be interrupted... and so on.
Not at all. As above, I'm merely suggesting that if a manufacturer sells a "10A switch" to Joe Electrician or Joe Public, that Joe needs to know
what 'rating' (based on whatever assumptions about utilisation, installation etc.) they are being presenting with - hence what it actually means.
I don't deal primarily with standards for accessories but I have access to some of them, so I might be able to help you, but the first thing to understand is that there are more than one 'rating' for any piece of electrical equipment.
Yet again, exactly. Since there is more than one 'rating', if a manufacturer presents (explicitly or implicitly) just one 'rating', the user needs to know which one is being presented.
It really all comes down to very basic, and practically very important questions - e.g. as far as the average domestic electrician is concerned, is it, or is it not, acceptable to have a bog standard light switch with 10A written all over it 'protected' by a B10 MCB? That's not an unreasonable question to want to know the answer to (without the need for a trip to the library), is it?!
Kind Regards, John
