If a cylinder has a high turnover, can the water temp be lowered ? Since a major contributor to Legionella growth is stale water, hence heating it above 60c. If the cylinder water has a turnover of 2-3 per day, can the temp be lowered to 30-40c ?
I was thinking of adding a small unvented cylinder for the kitchen taps. 35c is usually more than enough to wash dishes.The temperature can be lower with high turnover if it's an unvented cylinder but 30-40 is far too low for any hot water system.
If the outlet temperature needs to be that low for safety or whatever reasons, then install TMVs at the outlets.
Under current HSE guidance for domestic properties the only real advice that can be referenced is what is documented for Landlords and Legionella avoidance where stored HW should be kept at a temp of 60Deg, being the temp that legionella bacteria is destroyed. 50deg is understood to be the temp where the bacteria will start to die off so that is the min recommended in a domestic setting.Is there any guidance on temp and turnover ? i.e. 2 turnovers per day, min temp = 45c
It’s seems like a waste of energy to heat water in the cylinder and then add cold water to cool it back down. Especially when, allegedly, there has not been a single instance of legionella reported in the UK due to a domestic water system.
BBC Two - Trust Me, I'm a Doctor, Series 9, Episode 2 - What's the best way to clean your dishes?
How do you make sure your dishes are germ-free? Hot water or cool? Air drying or towel?www.bbc.co.uk
