Looking for some help with an issue I have with my water cylinder.
The currently cylinder is one of the double tank types, I think the bottom tank is the hot water part and the top tank is the header tank (cold water)
It seems to be constantly over flowing (via the overflow pipe). Ive checked the ball value and that seems fine (no leakage when in the off position).
From what I can see there is sometime a back flow from the bottom tank up to the header tank (via an internal pipe link).
From what Ive read, this can be caused by heating coil being knackered and leaking in to the tank (the cylinder is about 19 years old!).
Assuming the cylinder is no good, I wanted to check if I needed to replace like for like, I.E do I have to replace with one with a header tank.
The reason I ask is there seems to be a small black plastic header tank that feeds the cylinders header tank, and could really understand the need for two.
If the black plastic header tank is sufficient, I will just get a bigger main tank
