I got some of these but cannot see where to put them in the cistern.Parazone Bleach Blocks in the cistern are I find good for gradual scale removal and keeping clean. You will see that over time they break up and dissolve scale in the cistern and under the rim.
It's generally recommended not to use chlorine bleach products in cisterns with flush valves, as opposed to syphons, as it can rot the rubber washer. I don't know how much of this is 'cover the manufacturers a***' though.
Just don't be tempted to use those plastic cage efforts which hang in the toilet bowl - sooner or later one will fall in and they are the perfect size to get stuck in the drains, usually in the most inaccessible place.I think I will use them for a few weeks at a time with a break in between and not leave them in long term.
