So it would seem back to:-
New Circuit - A circuit for which there is no previous record.
However since you are not allowed to use a Minor Works for the replacing a distribution board and we have it would seem agreed that replacing sub boards in out building will not require notifying in the same was as a FCU does not require notifying then my sons idea does not hold true.
"120.3 Any intended departure from these Parts requires special consideration by the designer of the installation, and shall be noted on the Electrical Installation Certificate specified in Part 6. The resulting degree of safety of the installation shall be not less than that obtained by compliance with the Regulations."
This means there will be times where an installation certificate will be issued even though it is not a new circuit.
When my son said it I thought "how easy" but on reflection I can see the flaws.
By reducing my definition removing any reference of the form of the record it should mean even when there are no formal records just a photograph before starting is a record of the circuit existing so showing it as not being a new circuit.
Maybe "A circuit for which there should have been no previous record."
If there were any doubt I would err on the side of caution and notify as it costs £1.80.
If there were any doubt and it was going to cost £400 I would be less in doubt.
Is the real point. The change in what needs to be notified was also it would seem going to reduce the price but until these fees and published people will try to avoid paying extortionate fees to the LABC.
I looked up Cheshire and it would seem charge is split into 4.
Plan Charge £50.83
Inspection Charge £123
Building notice Charge £153.33
Regularisation Charge £184
This is before vat and is other then "rewriting" sure spelling mistake and it should say rewiring! Date 2011-12 but nothing showing for new charges since the change. Clearly no good looking up my County charges as in Wales. Charging more than the work costs to do is really what killed the Part P notification and it is hoped a more reasonable charge is now levied?
With such ridiculous charges we can expect people to go to ridiculous lengths not to pay them.
