Hi Folks, I'd like to add a backbox for a network cable and coax for a TV attached to the chimney (rear of the chimney in the kitchen, there is no fire place on either side).
The chimney also holds up a steel support for the upstairs joists.
Are there special limits that apply to the depth of chimneys and support columns like this? or is the 1/3 vertical, 1/6 horizontal still applicable?
The chimney is 2 bricks thick, but I'm going to need a 45mm backbox(2 gang) for the coax wall plate is this a problem?
Also, I'll have to drill a route for the the cables through the corner of the buttress to reduce the bend radius, they are only small wires, but even so, is it OK to do this?
Thanks for any advice!
