This is a glass lined Ariston and the scale gets right up to the immersion element. Maybe 8 or 9 inches.
Thats a heck a lot of scale flakes,only had the pleasure of other makes of cylinders here but still plenty of flakes.the scale gets right up to the immersion element
Thanks. What I will do, is work out the volume of the cylinder from the bottom to the lower immersion and inject at least that much descaler. Repeat if necessary until the Fernox indicates no further treatment necessary (it does this by change of colour). I should think that would remove all scale lying in the bottom of the tank, the immersion itself as well and the walls. Why do you say descaler wont clear it from the walls? When I descale my kettle, the whole kettle, including the walls, gets descaled.....................................................................You won't get the walls of your cylinder clean by using a descaling solution, but if you can empty any scale build up out which will encrouch on the bottom element it may help.
Once the inlet tube is scaled up, you have a big problem reaching it with a descaler. Regular descaling(whilst the tube still has freedom of flow) ought to ensure that descaler will reach the inside of the tube since it is not blocked.eternaloptimist1 if you have time consider developing a pumped system that will descale the inlet (internal) feed tube as mentioned by Stadan20 this dipped and diffused internal feed pipe is prone to scale build up resulting in poor outlet flow.
Could make you a few £££'s
yes you will,i wontOnce the inlet tube is scaled up, you have a big problem
How are you gonna avoid this eventuality then?yes you will,i wont
Out of the question. Too high a cost and no space.buy a water softener.
When you mentioned combi, I thought you meant a combination boiler. Did you mean this sort of a tank?....http://www.newarkcoppercylinder.co....rs--hot-and-cold-water-storage-cylinders.htmlI would fit a combi mate but others will probs advise not to ,
Thanks. I will look into this.
Please can someone clarify:The inlet of the cylinder loops upwards , this is where the scale builds up over the years , I’ve come across 6 that blocked up last year
