Hi Gentlemen
right if a lighting circuit has 10 lights 100watt each = 1000watt divided by 240 volts = 4.2 amps rounded up, so a 6 amp mcb to be used i believe
this to be correct
so if i got 15 double sockets on 70 meters of 2.5mm t/e how do i work out the design current.
thank you
this to be correct
thank you
