DEWALT DE7023 MITRE SAW STAND
Thanks crank.
No bolts supplied with the MAKITA.
I was only concerned that the MAKITA holes are say 10mm and the DW bolts are say 8mm. That means there is a 1mm gap all round on each of the 4 holes. Yes I can tighten them up so they don't move but, as you know, even a slight movement whilst in use can ruin a cut.
Maybe I am overthinking it!!
I will see how I get on with your suggested method.
Thanks again.
B
You can tighten enough to remove any movement but movement wouldn't matter anyway as when the saw bed moves so does the blade, the fact they might move independantly from the saw table doesn't matter as there is no fence on the table, only the supports
