Difficulties adding intermediate switch
No.
It's a switch wired with both conductors in the same terminal, or in terminals which are never connected together.
Never heard of a 0-way switch before - but have got a 2 gang intermediate switch, one of which will be wired as intermediate, and one as a 2-way.
The Wiki on here, and good ol' google serves us well for such things!
I've not had time to try the suggestions yet - but will report back when I have!
Whitling2k
Don't worry - he was just trying to be 'clever' (silly?). He was suggesting that a "0-way switch" would (by extrapolation from 1-way and 2-way ones) have no useful function - since, as he said, it would mean that the two conductors were always joined, or never joined, regardless of the position of the switch!
Kind Regards, John
I meant that as well as being able to wire an intermediate as a 2-way, you could also wire it as a 1-way or a 0-way.
You can also wire a 2-way or 1-way switch as the latter.
It's a perfectly valid extension of the naming system -
A 2-way switch has 2 working positions
A 1-way switch has 1 working position
A 0-way switch has no working positions.
I'm sure there will be posts in this form from people who have wired their n-way switch as a 0-way.
It's a perfectly valid extension of the naming system - ...
It is, but I don't think that makes it any less 'silly' - and, as you will have seen, you succeeded in confusing the OP, if not also others! I suppose you could use similar (technically correct!) 'extrapolatory' logic to define what you meant by, for example, a 0-phase electricity supply or a 0-gang accessory :-)
This is true, but I still don't think the "0-way" terminology is helpful!!
Kind Regards, John
I can do better than that for the latter item - here's a photo of one:
I can only assume the cables don't actually go where you think they do.
Correct answer!
I tried the set-up shown in the +/-/= diagrams and it was just weird - switches only worked when the others were in certain positions?!
so I thought this is odd... and pulled all the cables out ... and found another junction box hidden in the wall! tut tut.
So what I thought was the circuit cable was in fact the power from the CU. Which is why the 1-way switch popped the MCB.
I ended up replacing the entire lighting circuit for that part of the house using a (labelled and accessible) junction box - and am pleased to say I have made one more step to removing the rats nest of junction boxes.
There will be no more hidden/difficult to access junction boxes, and all the ones I'm installing are being labelled too - so future amendments will slowly get easier!
Thanks for all the help
lights out!
whitling2k
