Disc for cutting asphalt
18 Oct 2006
Buckinghamshire
I have to install two security posts for my daughter (Builders site manager tells me 3" asphalt and then MOT").
Will a normal masonry disc cut asphalt or do I need a special kind of disc.
Whose are the best - I have a relatively old 110v Makita 230mm cutter which takes offset discs - a noisy beast!
To concrete them in should I use standard 20mm ballast/cement mix (6/7:1) or is there a better mix to use?
