Fumbduck wrote
I was doing some head scratching and just figured that out as you posted. It must be late.
Well done any way.
I think you will get some grief however about the open vent.
Go to the heat bank website and click on "Mains conversion kit" and you will see how their system is put together.
I think the pump on the flow into the primary side of the plate heat exchanger would have been better.
The pressure drop across the plate is greater than the pressure drop of the water sitting in the vent pipe hence the pump trys to use this water as its just easier.
I wanted to make sure that if everything went pear shaped I could etill use the old setup
Well done any way.
