Dagnabbit, meant to add this too
Now the following doesn't make a great deal of sense to me but measurement shows it to be true. Go figure.....
I actually find that the recovery time from a large DHW demand has improved with the new setup. I think I was probably running the original setup at around 60-65C due to an inaccurate boiler 'stat which was upgraded to an on cylinder one with the rework. Obviously when you run water off it's replenished with stone cold stuff out of the loft tanks
When you run off with the heatex the return, whilst cold, is still warmer than water from the loft tank. I think my weak boiler setup is able to heat this to a slightly higher temp than previously. I'm also aware that to produce a bathful of water @ x degrees I need the exact same amount of hot water which is why the figures don't make any sense.
I do know that the stopwatch reports about 10% time difference though. Not a night and day difference by any means
I'm also aware I should probably get out more lol
