I asked for my DNO to fit an isolator between my meter and my consumer unit to avoid any need to get the supply fuse pulled when I have a new kitchen fitted in the summer.
They put in a double pole switch in an enclosure.
However only the live (phase) conductor goes to the switch
(ie 1 cable in 1 cable out , second pole left unused.)
The neutral cable goes to a henley block then direct to the consumer unit.
I had expected the double pole isolator to be used to switch both phase and neutral.
Is this the usual arrangement.
