That is the definition of a vaccine.If you mean 'total ("100%") immunity' (presumably in everyone who receives it?) what example of a vaccine which does that can you cite?
Small pox?
I will admit I thought once we were vaccinated we could not catch the item, like when I got the yellow fever one, but it did have a time limit, the flue jab was first where we needed a new one every year, and could still catch it.If you mean 'total ("100%") immunity' (presumably in everyone who receives it?) what example of a vaccine which does that can you cite?
Kind Regards, John
OK but the rental laws specifically states the 2018 Regs, not subsequent ammendments, therefore to comply with that law an inspection must be compared to that particular version.
You might, at the time, suggest recommondations for items include in subsequent ammendments and again items you personally recommend to enhance safety etc and I think that most of us would commend you for that.
What you must not do is to suggest such ommisions are defects when compared against the standard required.
You could end up in the middle of a right arguement or even get sued.
If you inspect in accordance with ammendment 1 or 2 and include something that is in the non ammended version and accordingly you defect it and code it.It does refer to the 18th but then says earlier editions may not be compliant but may not need upgrading.
So inspect to the 18th and liberal use of C3’s is in order
How can you get sued if you apply this logic?
Not in my book it isn't, regardless of what dictionary definitions you may throw at me. You seem to think that a vaccine will give total immunity to a disease (maybe even 'for ever'?) in everyone it is administered to. No matter how hard you try, I am confident that you won't find any vaccine for which that is true.That is the definition of a vaccine.
Yellow FeverAs with any vaccine, vaccination with TYPHIM Vi may not result in protection in all vaccine recipients.
Hepatitis AAs with any vaccine, vaccination with STAMARIL may not protect 100% of vaccinated individuals.
MMRAs with any vaccine, vaccination may not result in a protective response in all susceptible vaccinees.
.... etc. etc.Vaccination with M-M-RvaxPro may not result in protection in all vaccinees.
Smallpox vaccination certainly did not give "100% immunity". What it did do was to give immunity, at least for a period of time, to a high proportion of recipients. As a result, the number of people infected at any point in time dramatically decreased, hence a dramatic decrease in those able to infect others, with progressively reducing number of 'infective' people able to transmit it in each 'generation' of transmission - until, eventually, there was no-one 'infected' left to infect anyone else.Small pox?
They also say (relevant because some people in this thread have been talking about 'everlasting immunity') ...Historically, the vaccine has been effective in preventing smallpox infection in 95% of those vaccinated.
Although no longer used routinely/'clinically', smallpox vaccines still exist, but to thee best of my knowledge are only given to people in the very small number of labs around the world which still have, and work with, live smallpox viruses.Smallpox vaccination can protect you from smallpox for about 3 to 5 years. After that time, its ability to protect you decreases. If you need long-term protection, you may need to get a booster vaccination.
Example - if such a law was around say 50 years or more ago and you had incredible future insight and defected an installtion for no main bonding back then because you absolutely knew that it would be a defect in the future (nowadays)
What do you mean by "the 18th" - BS7671:2018 or Amd 2 thereof?So inspect to the 18th and liberal use of C3’s is in order
Unless qualified in some way, "earlier" means exactly what it says, with no scope for differing interpretations (no matter how daft that may be if taken to extremes).Earlier editions is open to interpretation ...
Ok, so something which does not do that is what?A 'good vaccine' will provide immunity from infection to a high proportion of recipients,
A 'not-so-good', but, quite possibly a nevertheless 'appreciably-better-than-nothing vaccine' (or, as with many, a 'much-bertter tha-nothing vaccine') - but still 'a vaccine'.Ok, so something which does not do that is what?
I seem to recall that you said that inspection should be to 'the current edition' (which is Amd2), didn't you - but if you identify things (even if only C3) which are non-conformant with Amd2, but which would have been compliant with BS7671:2018 (as required by the legislation), then you would be acting outside of the instructions of the legislation.
