FatGit said:I would do so yes, you need to tell him where you want sockets. He will use whatever style you want.
more specifically, will he need to know where appliances go? (ie cooker) and that kind of thing.
JohnD said:In a kitchen, I recommend a row of outlets 200mm above worktop height, cable run horizontally between them. An outlet every 600mm is not too many. At each position where you intend, or may one day decide, to put an under-counter appliance, put a 20A DP switch above feeding an unswitched 13A socket below. At each position where you may want an appliance above (like a cooker hood or an extractor fan) put an FCU feeding a flex outlet near the ceiling.
This method is very economical in time and materials.
You can run the circuit all the way round the walls (except at doorways).
The more you tell them the more likely the result is to match what you want and the more comparable your quotes from different electricians are likely to be with each other.jujhimup said:we have gone ahead and decided to get a full rewire done, at the same time as the central heating goes in.
with regards to planning - what do we need to know/tell the electrician?
do we need to tell him what kind of sockets, switches, light fittings, cooker, hob, fan, shower ... etc etc that we want to use? as we would be redecorating all the house after these works anyway - so would it help to know exactly what fixtures/fittings we plan to use? or doesnt it matter too much?
pbar on another thread said:... I went for the RCBO option as it seems straightforward and....well, I like em. They're sexy!
Chri5 said:Once the floor is up, electric cable runs will be quicker than the arterial CH, HW and CW feeds. So although both teams will work in common areas, there shouldn't be too many issues of engineer traffic congestion.
dingbat said:I would seriously recommend you get the electrics done first.
Albert said:I am sure you have a PC in the house, don't put one double socket there you will need many more; PC, monitor, speakers, printer, modem, scanner etc.
I honestly wouldn't bother.If you put in enough sockets to plug everything directly into the wall and later decide to move the PC setup the row of sockets left behind isn't going to look nice. PC equipment doesn't draw much power so imo there is nothing wrong with using a couple of power strips that can be easilly moved if you move the PC rig. Also its a good idea to have surge protection for PC setups and generally the easist way to get that is a suitable power strip (you can get surge protected fixed sockets but i don't think they are cheap.Albert said:I am sure you have a PC in the house, don't put one double socket there you will need many more; PC, monitor, speakers, printer, modem, scanner etc.
plugwash said:I don't think that PCs move very often, in any case this is what called design... The same way we can put in power strips for the kitchen appliences, the lounge where you will have your TV, video player, DVD Hi-Fi etc. I agree that the power strip at the end of the day is cheaper but is this a good design... IMO this is not.Albert said:I honestly wouldn't bother.If you put in enough sockets to plug everything directly into the wall and later decide to move the PC setup the row of sockets left behind isn't going to look nice. PC equipment doesn't draw much power so imo there is nothing wrong with using a couple of power strips that can be easilly moved if you move the PC rig. Also its a good idea to have surge protection for PC setups and generally the easist way to get that is a suitable power strip (you can get surge protected fixed sockets but i don't think they are cheap.
