Door Opening by itself
aahhh you have 3 hinges
take the three screws out of the middle hinge on the door and loosen the leaf from the door
watch the door through its arc and see if the hinge seems to move different to the door arc
Hi Big,
Did that, and no doesn't seem to.
do you think it's a gravity thing?
thanks
G
looking at the door when it's closed, the gap between the door and the frame at the top of the door is definitely wider than the gap at the bottom of the door.
yes it could be its just a case of ruling out any other causes
if its definatly leaning then the best solution will involve pulling in the top hinge 6mm and pushing out the bottom hinge 6mm
this will also involve moving/shaving the door stop
how big is the gap at the top!!!!
are the door stops planted on or a rebate in the frame!!!!
have you got a strait edge you can hold against the hinge knuckle to check they are fully in line !!!!
with the door shut hold the strait edge to the front and side off the hinge and see if they are fully in line
there should be no rocking or gaps and the batton should fully touch all 3 hinges alopng there length at the same time :roll: :D
Hi Big,
gap at the top is a few mm more than the one at the bottom.
dont know what you mean about the rebate.
yes they're all in line.
I don't quite understand all you're saying now, so I guess it's time to give up.
But want to say thanks so much for trying to help me. I appreciate all your posts and your time.
Gx
a rebate like your front door frame has a rebate for the door to sit in
or your interiour doors have a bit of wood [door stop ] for the door to sit against
not sure!?
very helpfull that photo
dont think its worth trying to fix as the dammage to the decore will be more annoying than a self opening door :D :D
lol thanks
my next big idea is to get a chain self closer
would rather have it swing close than open.
cheers for your help anyways
hello again,
so my temp fix is to put back the chain door closer.
the new one I bought doesn't come with instructions, anyone have any idea where I fit the clip which holds the plates apart so I can screw them into the frame and door?
It's one like this and comes with a metal plate bent up at one end with a slot from one end into the middle.
http://www.diytools.co.uk/diy/Images/DB_Detail/669611.jpg
cheers
you pull the chain out to tension the sping then you clip it to give you some slack to make it easier to fix
just a though before you drill your holes what width is your door!!!!!
the holes are already there as it had one before that we took out as i said
impossible to pull the chain out!
bit of 12mm ply 12" x12" with a slot in it to the centre clamp open slot ends into a workmate claw hammer to tension pin in
you can also do this when the cylinder is instaled in the door
...a metal plate bent up at one end with a slot from one end into the middle....
don't lose it. It is very difficult to adjust a Perko without it. the Claw hammer will easily pull the chain out (after you have fixed the tube into the door) so you can lock it and then fit the closer plate to the frame.
thanks John, did what you said and it worked.
rather have it closing all the time than opening lol
cheers all
xG
