whats the big problem gday , skin of limestone +cavity+ insulation+inner blockwork
As long as there are two skins there should be no problem with damp from outside. Also with a cavity you can obviously insulate it. Can you not get limestone faced blocks to use for the outer skin? I would have thought a purely limestone outer wall would be expensive? Also the porosity will vary depending on the type of limestone used so if a dense un-porous type is used there will also be no problems building it single skin.
As soon as I wake up
Every night, every day
I know that its you I need
To take the blues away
It must be love, love, love
Nothing more, nothing less
Love is the best
hehe.As soon as I wake upEvery night, every dayI know that its you I needTo take the blues awayIt must be love, love, loveIt must be love, love, loveNothing more, nothing lessLove is the best
I think its sweet!
yea its true that the stones are uneven and difficult to lay and leaning them against blocks would be easier but nothing to do with damp probs if theres a cavity,id a been honest and said them stones are a pain in the neck so il do a inner skin then cavity then another skin of block work then the stones,kind o guy iam,I've just got planning permission for my sister-in-law for a two storey rear extension to their house. They're just getting prices from builders and one builder who has been to look at the project has told them that he strongly advises that they build the walls with two adjacent skins of concrete block, then an insulated cavity and then the external skin of limestone. He's told them that as Limestone (the outer skin) is so pourus they'll get damp problems if they don't use a double skin of blockwork.
Firstly, does anyone know if using a double skin of blockwork would help prevent damp?
Has anyone ever built a cavity wall with a double blockwork skin on the inside so prevent damp? yea its true that the stones are uneven and difficult to lay and leaning them against blocks would be easier but nothing to do with damp probs if theres a cavity,id a been honest and said them stones are a pain in the neck so il do a inner skin then cavity then another skin of block work then the stones,kind o guy iam,
Is the builder trying to increase his time he's on site while work is a bit slack?
Most of the work we are involved with is built from either Limestone or Gritstone and as far as i can recall we have only once specified an inner skin of more than 4inch block once when the client specifically wanted thick wall. I personally have never heard of any of our clients having damp problems from single blockwork skin walls, certainly where the walls have not been retaining walls anyway??
AndrewSchofield";p="1241085 said:I've just got planning permission for my sister-in-law for a two storey rear extension to their house. They're just getting prices from builders and one builder who has been to look at the project has told them that he strongly advises that they build the walls with two adjacent skins of concrete block, then an insulated cavity and then the external skin of limestone. He's told them that as Limestone (the outer skin) is so pourus they'll get damp problems if they don't use a double skin of blockwork.
The builder you are dealing with is talking absolute and utter complete nonsense. I can assure you 100 % that the method of construction is complete overkill. In all my time I have never seen anything other than a regular two leaf cavity block construction( unless specifically specified for other reasons than damp)with expanded metal left between the horizontal bed joints at intervals to accomodate the stone external facade which is constructed with stone bedded onto a semi dry sharp sand mix, so no difficulty of lay.
No other detail other than a spread (wider) footing is required Irish housing stock is predominantly block built and most have stone frontage.
If you want a definitive answer contact Roadstone the main supplier of block to the Irish market at www.roadstone.ie. I have folders full of drawings in my office from over the years and not one of them would specify in the detail of schedule of works anything other than standard 4" cavity construction, sack this builder before he even starts, he doesnt know his a**e from his elbow.
yes andrew 75mm block a be fine , i know where there coming from its very hard to lay and balance the stones ,should find a merchant on line who supplys 75mm thermos,good luck
