hey lugs keep to what you know best and it certainly isnt laying bricks or stones ,aircrafts id say with them earsAnother point.....If building with a porous stone on the facade how can damp possibly be an issue, this type of stone allows moisture to dissipate naturally, if there are any concerns about moisture being trapped within the stone of a pourous material then this is readily overcome by building in a traditional method replacing ordinary portland cements with traditional lime mixtures that also accomodate naturally the dissipation of moisture, though this is another argument again.
Andrew,
If you use a full fill insulation, even a more random stone wall can be built without a backing wall.
Water penetration is undoubtedly the most common problem with buildings new and old, the cost and hassle of putting one problem with damp right in the future is often under estimated. With respect to ending up with a thicker wall, whoever did the planning drawings should have allowed for thicker walls. Opinion on the need for a block outer skin is divided, nevertheless you seem to be taking the advice that suits you.They're farmers and i though the extra cost of blocks, mortar, labour, bigger foundations would swing it but no?? Usually the mention of saving a few quid is the deal sealer with farmers!!
I did the planning drawings - why should i have allowed for thicker walls??
I've never detailed a job with a blockwork cavity wall faced with Limestone before and indeed, no-one at the practice i work at has in nearly 30years of detailing drawings
Wait a minute, you've been detailing stuff up for 30 years and you resort to a forum for backup! I just thought you were a Fred Bloggs doing a favour for someone. I hope your clients know they're getting such a service!
i think you should go back to the drawing room and think again
But you said no one in your office has direct experience of stone clad walls!It seems a few have heard of wall construction with the method he describes but most concur with our office practice that it isn't necessary.
Frankly, I think I’d be doing a disservice to my clients, private or commercial, if they knew I’d taken advice from an Internet DIY Forum and not spoken directly with experts in the trade.i posted the question on the forum to see if anyone has ever heard of it or if the builder is really talking out of his rear end
It’s the sign of a good planning application that takes account of the build method as well as the rest of the regs etc. It shows lack of forethought.You still haven't explained why you feel the planning drawings should have allowed for thicker walls?
Your practice website says 15 years BTW.in the office (which has been running for nearly 30years)
The builder you are dealing with is talking absolute and utter complete nonsense. I can assure you 100 % that the method of construction is complete overkill. In all my time I have never seen anything other than a regular two leaf cavity block construction( unless specifically specified for other reasons than damp)with expanded metal left between the horizontal bed joints at intervals to accomodate the stone external facade which is constructed with stone bedded onto a semi dry sharp sand mix, so no difficulty of lay.
No other detail other than a spread (wider) footing is required Irish housing stock is predominantly block built and most have stone frontage.
If you want a definitive answer contact Roadstone the main supplier of block to the Irish market at www.roadstone.ie. I have folders full of drawings in my office from over the years and not one of them would specify in the detail of schedule of works anything other than standard 4" cavity construction, sack this builder before he even starts, he doesnt know his a**e from his elbow.
legs-akimbo, as I understand it, the builder wants to do a traditional block cavity wall with 1 skin of block for the inner and outer leaves and face the outer skin with the stone. Experience of other contributers to the thread is contrary to your opinion. Your reference to www.roadstone.ie. appears to be a cast block manufacturer not a natural stone supplier, they are 2 different animals. There is no problem building with skins of 75mm provided it works out structurally and thermally. As with any cavity wall with respect to the cavity width, to keep building control happy, you need to pay atention to Part C regarding how exposed (or not) the site is.
what does lugs know, f... allThe builder you are dealing with is talking absolute and utter complete nonsense. I can assure you 100 % that the method of construction is complete overkill. In all my time I have never seen anything other than a regular two leaf cavity block construction( unless specifically specified for other reasons than damp)with expanded metal left between the horizontal bed joints at intervals to accomodate the stone external facade which is constructed with stone bedded onto a semi dry sharp sand mix, so no difficulty of lay.
Freddie you are quite correct, I misread the original post and assumed there were two internal skins and one outer with a stone facade.
My post above concurs with the detail specified by the builder in question, a 100mm block cavity wall construction, so in essence Andrew the builder is absolutely correct.
Building a single leaf stone clad internally insulated wall would indeed lead to problems with damp as this would lead to Interstitial condensation on the internal wall.
A well built cavity wall of block that is of course continuously seperated from the external, will harness the cavity to isolate moisture content gained from external conditions from moisture gained from the room. Both leafs then have the potential to dry out towards the cavity or their other face.
Single skin construction of all manner, and the proposed block/ stone non cavity is in effect single skin..... will have an inadequate U value without being internally insulated.
An internally insulated single leaf construction has the room face heated to within a few degrees of room temperature as it is warmed by the radiant heat of for example a fire. This means that the the point where vapour condenses (The Dew Point) is often at the face of the wall according to atmospheric conditions....condensed vapour in simple terms is damp.
Single leaf construction with internal insulation has to be given specific considerations to negate the possibillity of interstitial condensation other than just whacking up a timber rockwool filled stud or thermal liner board.
I mention this because the primary consideration for this construction should be the U value of the walls and I work this out to be around 3. on your preference if non insulated.
whereby the cavity proposed build would be around 0.32 which is a huge difference.
These are the kind of things I would have thought you would have learnt Andrew or most certainly would be second nature to your colleagues in the office.
