The filaments in ELV lamps are thicker, and so can be run hotter and tend to have longer lives.It's a pretty basic question, and I'm probably just being dim, but I've often wondered what are the perceived advantages of (LV-driven) ELV lighting (as you indicate, some of the disadvantages are fairly clear), except in those situations in which one wants/needs ELV for safety reasons?
Thanks. That makes sense. Is that the only advantage of ELV (other than 'safety' where relevant) of which you are aware?[The filaments in ELV lamps are thicker, and so can be run hotter and tend to have longer lives.
Agreed - and thanks. I was just worried that I might be missing something 'obvious'/major, but it seems I probably wasn't.Yup. ... I suppose, in theory, that given they are supplied by electronic power supplies there's the potential for soft-start and close control of constant lamp voltage even if the LV supply fluctuates, but I wonder how much of either of those the cheap rubbish sold in the sheds tends to do....
Filaments in ELV lamps are also shorter and thicker than those in LV lamps of the same wattage which makes them physically stronger and less prone to breakage,
The filaments in ELV lamps are thicker, and so ... tend to have longer lives.
Ooops sorry I missed your postThe filaments in ELV lamps are thicker, and so ... tend to have longer lives.
At my ma's house, there are still some Thorn ELV dicroics working that were installed in 1991.
