Thanks, so a new cylinder "should" heat the water up in about half the time. Which would make sense with my old house heating the newer blue vented cylinder in about 40 mins instead of 90 minutes. The insulation on the cylinder isn't very thick either, although I do have an old jacket to put on which will help for now. It seems a new cylinder is on the cards, then I should be able to balance the heating and hot water better so I don't lose heat downstairs. When i get the boiler serviced I will see what they say also. Many thanks.
