That is probably wishful thinking; lots of air in the pipes judging by the sound when the heating comes onEh its a combi so pressurised system close auto air vent release pressure out of bleed nipple .
System is then vacumed up
Carpet can not be rolled up without moving heavy furniture.Take necessary precautions to protect carpet best rolled away but plastic sheeting and old bath towels sufficient.
Also dodgy floor and suspect ceiling from flat below; one mishap, and it will cost me a new ceiling.
But if I am correct, and the valves do not shut properly, I will have a lot of water coming out. And I fully expect to have to make completely new connections on at least a couple of valves due to damaged olives/threads or incompatible threads.Change each valve , one a time very tiny bit if any water will come out if twin entry valves put d/cock in other end of rad at same time if seperate valves use the ones with built in d/cock.
The problem is: I want to drain it properly before I change the valves.After finishing job you can drain and flush properly
