Have a bit of bolz man FFS.
You're supposed to be a "professional"
Not a wind up, was just hoping someone had a clever trick that I am not aware off to empty the system without risk of a mess.
Guess not.
Guess not.
You have not seen the way this flat is done.I don't see any reason why it should fall off, ...
That would involve a lot furniture moving, and also do little to safeguard the ceiling below.Roll the carpets back will give you some comfort perhaps.
This could well be an option, will have a look at merchant to see how bad the wallet will suffer.if you can't/dont want to roll back carpets go too decorators merchant and purchase plastic carpet protector, quite pricey comes on a roll and works like cling film, 2 layers on carpet & up skirting, paper towel around slits for pipe if any. Place heavy duty dust sheet (cotton) similar to BG sheets, they dont let water straight through due to heavy weave, and use a wet & dry hoover. cover any areas you are likley to walk on with plastic & dust sheets also, just in case sh*t happens and you have to hot foot it with a dripping rad out the property.
