Eh. Plumb centre stock them hooting. Although not used very often, when you need them they are quite handy.Oh ffs. No. If you want a slip socket then you are best off trying a sweet shop. You can't expect a plumbers' merchant to carry wierd stuff like that.
Won't get away with leaving the rads full would it just carry on dripping?Yes open bleed points. Yes most merchants sell them. When i have been stuck for one in the past i just get the file out, and file the stop in the middle of the socket.
Where there's a will there's a way! It is possible to solder with a bit of water still in pipe but depends on pipe size etc.Won't get away with leaving the rads full would it just carry on dripping?Yes open bleed points. Yes most merchants sell them. When i have been stuck for one in the past i just get the file out, and file the stop in the middle of the socket.
But they dont do compression slip sockets? The pipes in a stud wall so wont be assesable at all after. Its my friend s house just helping him out. Was going to put two slip sockets and a small bit of pipe in
