It's far easier to repair plaster damage than brick damage. Here is what 2 stupid sky installers did here. One bit of damage wasn't enough so they drilled another hole in the same fashion when sky+ was installed. There is more damage around the house where multiroom was installed, this time the corner of the brick is missing. I don't watch TV so all the cables are removed. But I will have to replace the bricks now. It's a job I don't enjoy doing.
I also try to fit conduit in the walls to protect the cables where practical, though it often isn't, and drilling a large hole for a 1mm cable is a lot of work. When I do, I use a 22MM core drill to cut the hole.
Leaving the cable sticking out the wall is fine, the tape should be used only for keeping the damp out of the end of the cable. The cable must not be connected the other end.
