masona said:
This is how I was taught, if I'm in 4th gear coming up to a traffic light, I use all the gears to change down from 4th, 3rd then 2nd.
Ah yes, this one caused a fair few disagreements in my family. My dad learned to drive in the 1960s, when cars were still referred to as "horseless carriages" and you had to swerve to avoid dinosaurs.
I learned in 1997, when cars no longer had a Fred-Flinstone hole in the bottom. I was having lessons from a rather good instructor (ex-police driver), and was lucky enough that my parents were willing to take me out to practice in my mum's car.
But after a few drives, I wouldn't go driving with my dad any longer. The main points of contention being:
1)
Block changes: the correct method as taught now when approaching say a roundabout is to slow down (not using the brakes, but by anticipation). When you are at an appropriate speed, change down from 4th to 2nd missing 3rd.
2)
Correct use of 5th gear: If you learned to drive pre-1985 or so, it is unlikely you were taught in a car with a 5-speed box. The typical supermini is perfectly happy to drive at 30mph in 5th gear in a straight line. In fact the manual for the Ford Fiesta my instructor taught in stated that it is suitable to use at any speed from 29mph. Many "more seasoned" drivers treat 5th gear in the same way one would treat a 2-speed overdrive axle, that is you only use it on the motorway. Of course, it is different with bigger and faster cars as the gearing may make 30mph impractical in 5th.
3)
National Speed Limit on a dual carriageway: Did they change this at some point? It is 70mph, but I have noticed so many people refusing to drive more than 60 on them. And several people of the "learned to drive in the 1960s" generation have told me it is 60. Even though it isn't.
4)
Correct use of lights: Sidelights, or "parking lights" to give them their alternative name, are not to be used for driving. If it is suitably dim that you need any lights, use headlights. After all, lights are so others can see you more than so you can see others. And a dimly glowing parking light is no good to be seen.
Now I know I am not alone, most guys I knew learning to drive at the same time had the exact same disagreements with their fathers.
However, I do warn you that you will hear a fair amount of BS from your kids! I took my sister driving when she was a learner and she told me several porkies that she claimed she had been taught:
1) when reversing there is never a need to look behind you, mirrors alone suffice
2) there is no need to brake BEFORE a corner, THROUGH the corner is the correct way
3) Adam should shut up before he is made to walk home (well, she did repeat that one a lot
You may even have your son tell you it is now taught to use front fog-lamps at all times, and display blue LEDs on the washer jets
