I have a Vaillant combination boiler about ten years old. Since having an expansion vessel fitted recently, the boiler makes a noise like a plane going over when the hot water is running.
The noise starts soon after the hot water is running and goes down in tone lasting up to thirty seconds, then there is a silent pause for a few seconds an it starts up again becomign louder and the cycle repeats until the tap is turned off and often the pipes make a one off bang at that point. I am not certain but I think the droning has also happened sometimes when the heating is on but rarely. It does not occur when running cold water or when running the hot tap when the boiler is turned off.
The plumber who fitted the expanson vessel suggested it was the fan and applied some WD40 but this has not worked.
I would appreciate any other ideas on the possible cause and solution to this problem. Thanks.
