Boiler falls of wall snaps gas pipework customer returns home flips switch need 3 new homes there.
Rodents climb into boiler flue not correctly fitted by non qualified person giving advice to take flue out to inspect but loosely refit it.
Rodent nests inside blocks flue.
Poc fill room boiler is in and travels along void filling nearby homes with Oder less carbon monoxide, they pass on.
Boiler finally stops, use find boiler after investigation.
All faults I have been to like the last have happened and no offence to you electrics are bad, but joe is giving out advice and suggestions that may be used by non gas trained persons may use to DIY fix boilers and gas work.
If you need to link videos please use YouTube and enter natural gas explosions, gas explosions and so forth.
Carbon monoxide is odourless can travel and is silent can be a result of someone tampering with their fan.
Do not know why you are here but joe needs to stop with giving advice on gas issues, which every installer/rgi on here suggests to him not too.
