Dry radiators not heating (Ed.)
7 Dec 2024
Hello
Any advise mosr welcome .
Have gadb3 plumbers over all are stumped.
I have a top floor flat and have not heating .the rads dry no water in them.
The plumbers are stumped on how to get water I the system to my flat .
The other flats have heating just mine without
Hello,
This should be in Plumbing section.
Can you start by stating what type of system you have? Is it communal flats with a boiler house?
Thankyou
Yes it's communal a converted house into individual flats with a boiler in the basement. The other flats have heating just not mine at the top.
Hello
Quote
Somebody else has closed a valve somewhere, but would have thought a plumber or 2 should be able to identify.
Do you rent or own ?
What fills the system? Is there a feed and expansion cistern on the loft/high up somewhere? Should be pretty simple to track down for someone on site.
Not a plumber or heating engineer but you probably need to give more information. Is your flat's heating system self-contained, i.e., you have your own boiler to provide the heating or is it a communal system of some sort? And if you do have your own boiler, what is it, e.g. a combi, or do you have header tanks and cylinder etc?
Information given on a general discussion thread. I advised it should have been in Plumbing section, so new one has been created.
Thanks for reply.
I know should be easy enough but cant find the feed or expansion tank .each plumber is stumped
Thankyou
No boiler I the flat .a communal boiler in the basement. Cylinder tank in the flat and water tank above it .
No expansion tank and the diverters are ok .
So the boiler serves 4 flats mine at the top .
Thankyou
Do you know if there’s a heat interface unit anywhere? I think there should be a filling loop. How will you be paying for usage?
