Just seems to be how a relativly low level current acts upon the nerves in the skin?
I can get that from my laptop
Like many modern electrical items, it's only got a 2 pin supply, but probably has input filtering caps. At work it's fine as I have it connected to an external monitor and it's 'earthed' through the monitor, but elsewhere I can get a tingling feeling where my wrists rest on the case.
Just checked, using an earthed 3 core cable it's OK, using a
"duckhead" adapter (no earth connection for the power supply) there's 40 to 45V on the case
voltages below 50v are considered relativly harmless in most installations, but on farms on the like it falls to 25v.
And I think back to how cavalier we used to be with 'lectrics when I were a lad and worked on a farm
Among other things, there was this long extension lead we used whenever we needed power away from the very few sockets. An old rubber job it was, with dozens of bits of tape over the cracks, and the 13A socket on the end had this lead coming out with a crocodile clip on it. No-one knew what it was for (I do now having read a few posts here), and it would often be clipped onto the bit of equipment we were using. The extension lead was 2 core - I now wonder if it wasn't some bodge up 'cause that's what was to hand, but rather an attempt at not exporting an earth from one building to another and the instructions for using the earth connection were never passed on.
And on another occasion I had to do some welding on a door. I recall that with the welding earth attached, I could feel "quite a tingle" off it.
Probably a good thing we mostly wore wellies
