Earthing of metal boxes
Different things frequently have the same name.
It is a screw which holds the socket in place.
What else would they be called?
I might say Faceplate screw
this is a Socket cap screw, or socket headed screw. Smaller ones are more likely to be splined
Or socket button head, very popular on bikes
Indeed - but it seems that this is a case of the opposite - the same thing having different names ....
It is a screw which holds the socket in place. What else would they be called?
Oh, I see, is that where the "socket" (of "socket screw") comes from?! (I confess that I hadn't thought of that possibility!) If so, do you also recognise "switch screws", "FCU screws" etc. ?
Kind Regards, John
By definition, obviously.
Have you been taking some winston pills?
There are even machine screws for holding machines together.
coach screws for holding coaches together
countersunk screws for holding... um... counter sinks.
Indeed there are. I have a suspicion that all the things we've been talking about (fully threaded and designed to go into threaded holes, rather than to 'screw' into materials like would) may be classed as 'machine screws'. A more interesting (and probably less well understood) distinction is between a machine screw and a bolt (intended to be used with a nut). IIRC, a bolt is not fully threaded, whereas a machine screw is - but I may well be wrong in that recollection!
Kind Regards, John
