B
Big_Spark
Breezer..he doesn't work on Pylons, that is The National Grid, he works on the rural overhead kit that is at 11Kv or below. The highest he goes is about 20ft!!
Sounds just like TN-C-S / PME to me.FWL_Engineer said:Yep, all it is is an adapted TT supply where they ground the Neutral in multiple locations with the lightning conductor earth rods and at the substations. However in your home they install a PME head and split them again for the a standard domestic installation with seperate conductors...that is how it was described to me by a friend who is a 24/7 Overhead Engineer anyway
Securespark - can you run through the definitions of the meaning of the letters T, N, C & S in 1st, 2nd, 3rd and 4th places and show us how an overhead supply cannot be TN-C-S?securespark said:When I said PME, I was not referring to TN-C-S (because it is an overhead line) but the principle of PME, the neutral bonded to the earth conductor at the intake.
The words "hairs" and "splitting" come to mind - have you, or anybody, ever heard this distinction before? Assuming (??) that the designations are some sort of EN standard (??) what does that say about the exact definitions?FWL_Engineer said:Ban, as far as the IEE and the supply compnaies are concerned these are not TN-C-S..OK, I 100% agree that in priciple it is..so do they?? However they say that as far as they are concerned a true TN-C-S can only be supplied by a concentric cable in which the Neutral and Earth are combines, then split at the consumers intake.
I should jolly well hope that Neutral and Phase conductors are wholly separate, otherwise it'll be jolly hard to get any electricity down the jolly wires...They said that as the Neutral and Phase conductors are actually wholely seperate cables and thus can be replaced independantly, this does not neet the definition of TN-C-S.
So if you had the identical design, but installed that way from scratch, what would it be called? I don't see what difference adaptation makes.24/7 (Energis) said that they understand the confusion, it causes problmes with their engineers, but as the Neutral has been ADAPTED to have multiple Earths, not installed with dedicated earth connections, it cannot be classified as TN-C-S. They suggest it is called a "Hybrid PME"?
It's a confusion of little import. AFAICT I've got TN-S, which makes life a lot simpler...Confused..you will be after this episode of
"Electricity, the story of the UK supply Industry!"
