The TT calculation was not a "quote" but a worked example of how these figures are derived , obviously you don't agree with the IGE/UP documents?
You do need to brush up on your English mate, you don't seem to be able to read straight forward sentences.
I clearly stated two things:
1. The document's calculations are correct, at least as far as I know.
2. The calculations, correct as they may be, do not show, let alone prove, why changing the dropt test duration from 2 minutes to 100 seconds would endanger the safety, because some of the parameters are nothing more than somebody's choice.
But that is all a deviation from the original subject.
You still have not explained how you balance a system without Draytons, nor what the result is when people open the trv's fully, nor what you actually measured over the boiler F&R during your last benchmark completion, nor what instrument you used to get the readings.
Surely a man with your enormous experience knows how important it is to stay focussed on the job and finish it properly before starting on something else.
Be a man, and don't try to wiggle out of things.
