that maybe your take, but you maybe forced to accept the reality if you were ever to be in that situation.Not just harsh, but I would suggest also unrealistic/unacceptable.Hi John, That maybe the case, and yes, that would mean that there would probably be a lot more 'unsatisfactory' reports the day after a regs change. Harsh to some people but i guess thats just the way it is.
yep, that sounds about right, bummer, isn't it? But equally, the upgrade work involved may only be minor. After all, it isn't difficult or expensive to install a small enclosure with RCD for sockets somewhere at or near to the origin of the circuit, is it?Those people needing to have a 'satisfactory' EICR would be forced to have (perhaps major) work undertaken everytime the whim of the IET etc. caused them to 'update' the regs.
but there are also cars which would be deemed unacceptable due to a change in testing aswell. (think back to when emmssions tests came in, a lot of cars got scrapped as a result of failure to comply, bummer again!Many pre-existing things (e.g. cars) continue to be regarded as acceptable even if they would not be compliant with current-day regulations for new products.
yes, but those code 3s may have come about as a result of a change in reporting but are inconsequential. Just illustrating that you don't have to paint everything black due to changes, its not always that bad and changes made are usually to try to promote safety and thats not a bad thing IMHO.Although, having said that, as i'm sure you know, if there were only code 3 on the report then the overall report would be satisfactory. (as an example, rcd protection for concealed cables, only a code3, so nothing to be concerned about).Indeed, but I thought that's what this discussion is about.
As you say, a Code 3 is really a different kettle of fish - it is essentially just 'advisory' (indicating non-compliance with current regulations) and does not result in an 'Unsatisfactory' result. That's surely why there is this discussion about people who would give a Code 2 to things which (perhaps by applying 'common sense') others would classify as Code 3?
As above, isn't the decision of an electrician as to whether to give a Code 2 or Code 3 something which can (and hopefully often is) based on the application of a degree of common sense?Re: the common sense approach. .... If it were down to the likes of you or I, I'm sure we would apply common sense when devising a protocol for reporting. However, we were not involved and common sense may be due to arrive on a later bus, but i won't be holding my breath
Kind Regards, John
Yes, but i know you are very well aware of how some people like to apply a blend of common sense and guidance/regulation, this can produce varying results can't it?
