Same as all electric showers. It's inevitable when you only have 10kW or so to heat the water.I've got a Mira Vie electric shower but the pressure isn't great at all.
That is because your combi boiler probably has 30kW of power available for the hot water - 3x more than the electric one.(The bath has a shower attachment off the taps and the pressure on via (from the boiler) and with a similar shower head is excellent).
The answer is to fit a mixer shower, which will involve installing a pipe for the hot water from the shower location to the boiler.
Note that although this will result in a decent shower, you won't be able to use it at the same time as the other one, which is probably why the electric thing was fitted in the first place.
