I said that if the flow rate/pressure at the shower was due to poor plumbing there was a solution installing a pump just before his shower,some showers need 1bar of pressure for them to function,some need as little as 0.5bar,if you have 3bar coming into your property and only 0.5bar at the shower then there is a problem with the pipework isn`t there? Mr Plumber of 2010 Bye.
Problem with the pipework??? do you recommend a full repipe? Read earlier in the thread mate. The poor electric shower performance is because ITS AN ELECTRIC SHOWER it is designed to slow the water to allow it time to heat up the water. Hense the hotter you select the water the slower the flow.
How many shower have you fitted??
Would love to see your customers face when you fit these pumped showers to solve non existant plumbing issues and they find the shower is no different!!!!
You could put a 4bar 20 litre/min pump and a 28mm feed to the electric shower and it would give the same performance!!!! 10kws will only heat a set amount of water
BASIC BASIC stuff. You cant be a plumber or even a very good DIYer this is first year apprentice stuff.
A battle of wits is no fun when your opponent arrives unarmed
