If it's a 100mA RCD then you can add a number of other regulation contraventions to the list.....
he may be qualified and indeed you don't need to be to issue a EIC, but the fact that he's retired means that he is no longer ( if he ever was ) part P registered and that means you have to have notified the LABC about having the electrics done..
it's a building regs certificate that you'll need not an EIC..
anyway back to the problem..
you were "knocking up" when it happened so one of a few things has occured..
1) you slapped wet plaster into or round a socket or light switch and this has caused a N-E short..
2) you did the fabled "plasterer's trowel trick" where you've managed to slice into a cable in the wall with your trowel..
3) you spilled water on the floor which has run into a JB or light fitting under the floor
4) you've move a cable and it has caught on a backbox because your sparkie didn't fit gromets and has caused a short..
Sorry - that's complete nonsense - he is either qualified or he is not. If he is competent to issue an EIC then his status as employed/self-employed/retired/unemployed/etc is irrelevant.Firstly the electrician is qualified but not to give me a certificate as he had retired.
How?I need to obviously get this done asap.
Defaming his character? This workman who has left you an installation which doesn't work properly, may be dangerous, does not comply with the regulations, is probably illegal, and who himself did not think that he could certify it even though he did the work?Can we try and stay focused on the technical problem rather than defermating the character of a workman
He clearly has. There is no chance that he has not.that may have done nothing wrong,
You did ask:quoting regulations is not why i am here
Can you please enlighten me on the regulations? What is the problem?
Yes, but not all on a single RCD.The property is a small terraced and only needs few circuits,
Actually people have suggested a number of scenarios.What no one is still unable to answer is why the RCD trips when ANY circuit is on soley.
Not the sort you need.Also, any electricians should be able to supply a certificate if they test the wiring?
They didn't need the same sort of certificate which you need.what about properties that dont have them from years ago that are then coming up for sale!?? infact my parents had an electrician recently that did theirs.
It's probably not 80mA.Im not at the house so i cant tell you what the switches have on them, but i remember seeing 100A and 80mA on the RCD - Does it say on the website where i linked to Wickes? Might be be best for your technical specs.
ok, wont the act of turning off the circuits one by one at the trip switches eliminate the need to remove the live and neutral wires? (Which i have done but they still trip when they are on individually)
The Plastering was only done downstairs so there should have been no floorboard leakage!
There quite possibly could have been water splashed into somewhere but all of the sockets that were in the room (And most of the downstairs sockets and switches) have been checked, they are not wet inside or have plaster in, this was over a week ago, they should be dry by now. if i could narrow it down to the circuit im sure i could find it but like i said turning everything off and only allowing one live circuit isnt helping which is my confusion!
