Lights controlled by two-way switching, when the light is off, I like both switches to be in the proper off position, and not both in the 'on' position!
For me it's plate screws all set the same way. I always position them so the slot is at 45° with the upper end of the slot to the right. If it's a larger grid plate with 4 or more screws I set the slots as sort of a circle, the corners at 45°, any middle screws vertically.
I'm borderline OCD but mainly having to check I've locked the house and garage. If your habit doesn't take over and impact on your everyday life it's not OCD, I'm told.
Intermediate (4-way) with three switches makes things more complicated since you can't have all up and all down for the same state, but I like to make sure that with all switches in what would normally be the off position (up for U.K., down for U.S.) the light is off.
