Electrical socket is live but nothing works in it?
I can't say for certain that I've sorted the dodgy line under the worktop, all I've done is fit a new socket and cut away the heat damaged wire to new bare copper.
It sounds as if you have probably 'sorted' that, but the electrician will be able to confirm.
I did check the fuse in the switch above the worktop and it was fine, swapped it for another too and same problem.
Fair enough. It remains possible that that 'switch' (FCU) has become faulty and needs replacing. Again, your electrician will be easily able to ascertain that.
Kind Regards, John
There could be a dodgy connection in that socket.
Dare I make a cheeky suggestion that the two FCU's are both spurred off it? ;)
