Another theory - you were live and the neutral and earth were providing a return path!
Unlikely as I think you might have noticed that, but it doesn't take a lot of current nor a particularly high voltage to light those neons...
Another theory - you were live and the neutral and earth were providing a return path!Unlikely as I think you might have noticed that, but it doesn't take a lot of current nor a particularly high voltage to light those neons...
Hi, I'm new to the site so may I attempt to answer a not too important or safety related question.
With this type of test screwdriver you do not touch the end of it to test for voltage - only for continuity, testing fuses etc.
Interesting theory. OP, does the screwdriver contain a battery and an LED rather than a neon? I've seen and even had the pleasure of using one of these once, and AFAIK there's no way to tell any difference between the indication of continuity or voltage. What's more, it seems practically anything that conducts even a little (like 10KOhm or so) will show up continuity. So, if you were using one of these and were rather well earthed yourself, it's perfectly possible the continuity indicator could have lit.
Many thanks to all of you who have responded to this. I'm going to give up on the neon screwdriver because there is a risk that it can give a misleading indication - and I'll try one of those Martindale Voltage Indicators.
