Right, as you say.
Let us take a step back and look at the string. If I understand it, you have the following:
Seat > plug with 13A fuse > FCU with 13A fuse > cable to consumer unit > 40A MCB > 30mA RCD
When things go bang, if I understand you correctly, all of the fuses and the MCB and RCD blow or trip, is that correct?
There must be quite a big fault to blow a 40A MCB as well as the 13A ones.
Firstly, please confirm that my assumption above is correct.
Then, Please find the instructions for the bidet seat and find out what size fuse there should be in the plug.
(Thoughts) I'm not sure why there is a need for a plug&socket and an FCU, but there's no sense used, sometimes.
