Energy monitor clamp behavior!? (Looping live thru clamp)
In that case, is not by far the most likely explanation the one that was given right at the start - namely that putting additional things through the sensor is stopping in 'closing' (and hence completing the magnetic circuit) properly?
:oops:That was it John, even a fraction of a mm causes a massive drop in the reading! The extra bit of sheath, rope, etc... in the sensor must of pushed open the clamp, only by 10th or so of a mm, but that's all it took.
Aha! As I think bernard said when he first mentioned it, it takes only the tiniest gap in the magnetic path to have an enormous effect - the two parts of the magnetic core must be, and remain, in contact.
Kind Regards, John
What happens if you remove the sheath so that you can get a double loop of conductors in there without pushing the clamp open?
Indeed. Hopefully the laws of physics will start showing themselves properly with the clamp properly closed, and he'll get the answer that we would all expect!!
Kind Regards, John
