Has anyone suggested buying a cheap clamp meter ?
I don't think so, and if there were still some doubts, that would clearly be a good idea, but there surely aren't any significant outstanding doubts, are there? We have a single pair of meter tails going only to a CU, the BT man has confirmed that the main switch in that CU is performing satisfactorily and yet, when that switch is off, the meter continues to tot up usage. That's all pretty 'decisive', isn't it?Has anyone suggested buying a cheap clamp meter ?
Kind Regards, John
the quality, length and content of your posts is telling me something but I don't know yet what it is.
It wouldn't have been a waste of money or time in this case, since the OP was attempting to find where an 'unexplained' ~2A of current was going. However, it's now almost certain that it's going nowhere, and is just a figment of the imagination of a faulty meter!Waste of money, waste of time. Clamp meters measure current not watts.
I had in mind more for confirming 'zero' when amps and watts are the same.Waste of money, waste of time. Clamp meters measure current not watts.
Is there a wattmeter to which I could have linked?
To be honest I don't know of a suitable device
CLICKA wattmeter needs to measure current
No, that's because they are a huge corporation and we are no longer customers.which is why Scottish Power want £50 for a check meter I presume.
To be fair, it's probably also because, without such a deterrent, there would probably be countless people requesting a check meter because they felt that their bills were a bit high. I presume that SP are by no means unique in this respect, and I also presume that any of the companies would waive (or refund) any charge if it transpires that the meter actually is faulty.No, that's because they are a huge corporation and we are no longer customers.which is why Scottish Power want £50 for a check meter I presume.
Yes, they should. BT do the equivalent of that with (telephone) callouts - one is warned that one will be charged (after the event) if a problem proves to be due to the customer's equipment or wiring. I think much the same often happens (per their Ts&Cs) will warranty callouts.Then they should bill the 'customer' after the work has been done as I have to do.
