This is getting confusing. Are you sure you're reading the gadget correctly? I assume you mean 2.7 kWh.2.I have continued monitoring electricity meter overnight still using 2,or 3 units overnight - only Fridge/Freezer in kitchen and upright Freezer in garage still plugged in.
3. The monitor gadget I used on both the above appliances showed Cost ranging from 83p to £1.18 pence energy usage 2.7 watts for each appliance over 2 nights measured.
We're obviously seeing contradictory information. If it really is true that your meter was registering substantial consumption when everything (even the CU main switch) was 'off', then the meter is faulty. Full stop. ... but now you are introducing new uncertainties!You're not as confused as I am John!
1.37 kWh over what period of time? I presume that it was reading zero when you started the test? I'll see if I can find anything about it, and how it should be used.The gadget I used" Energenie Power Meter Model ENER007" did show 2.7W under " Energy" display. "Cost" shows 1.371 Kwh for upright freezer in garage. .....Does this make any sense to yo?.
It would take over 3 weeks for a consumption of 2.7W to get to 1.371kWh...The gadget I used" Energenie Power Meter Model ENER007" did show 2.7W under " Energy" display. "Cost" shows 1.371 Kwh for upright freezer in garage. .....Does this make any sense to yo?.
It would indeed, but 2.7W is presumably an instaneous figure which happened to be there at the moment the OP was looking. When the compressor is operating, the figure would obviously be very much higher than 2.7W.It would take over 3 weeks for a consumption of 2.7W to get to 1.371kWh...
I've been looking around some of the 'energy saving' websites, and the figures they give for the consumption of freezers and fridge freezers tend to be in the range 0.8 - 1.7 kWh per day (i.e. about 0.25 - 0.6 kWh for the 8h 'overnight' periods you were talking about at the start of this thread)."Cost" shows 1.371 Kwh for upright freezer in garage.
Those figures certainly don't seem to be indicating any dramatic difference between the two meters. It may be time, whilst the check meter is there, to repeat your experiment of switching everything off overnight. If the check meter, as well as the existing one, continues to show usage under those circumstances, then you clearly would have a problem (some 'overlooked' load).Hello John W2 and wontdothat agiain. Check Meter installed at 9am Monday 10th June 2013 reading 00002kwh currently reading 12.5 kwh. Existing Meter reads a consumption still of 3kwh overnight and 11kwh all day 10th June usage. It would appear that check meter is reading a usage of 1.4 kwh overnight wheras existing meter is reading 3Kwh being used overnight.Does this make any sense to you?
That's all true, but don't forget that he is looking for (hoping/expecting to see) a fairly larger difference between the two meters. If such a difference does exist, it should become apparent pretty quickly.don't try and look at the figures on a daily basis, try and look at it weekly as if there is a small difference, it will not be as apparent as the 2 meters are out of synch so you will need to disregard the first unit doing it daily
